.drone.yml文件如何获取在drone的Repositories的Settings里,新增Secrets的变量
kind: pipeline
type: docker
clone:
disable: true
steps:
  • name: clone
    image: drone/git
    pull: if-not-exists
    environment:
    HUSHUAIPWD:
    from_secret: HUSHUAIPWD
    commands:
    - echo $HUSHUAIPWD
  • name: build
    image: maven:3.8.4-jdk-8
    pull: if-not-exists
    volumes:
    • name: maven-cache
      path: /root/.m2
    • name: maven-build
      path: /app/build
      commands:
    • $MAVEN_HOME/bin/mvn install -DskipTests=true -Dmaven.javadoc.skip=true -B -V
    • mkdir /app/build/hive-function
    • cp -r target/lib target/hive-function.jar /app/build/hive-function
      volumes:
  • name: maven-cache
    host:
    path: /usr/local/drone/cache
  • name: maven-build
    host:
    path: /usr/local/drone/build
    trigger:
    branch:
    • master
想问下大家,已经配置了HUSHUAIPWD变量了,但是在这段代码里为什么取不到HUSHUAIPWD变量的值呢
